Scanner Driver perhaps?
25 Jun 2006
Somewhere East of Eden
Can someone please help me?
I’ve not used my scanner (Agfa ScanWise one touch) for a couple of years….. I’ve just tried to scan a photo and I get the following error message:
“ScanWise has detected that your monitor/screen is not configured to display sufficient colors. Use the Control Panel to switch the display to at least 65,535 colours before re-launching ScanWise (also termed “High Color 16bit” or “Thousands”
My monitor is a Samsung syncMaster 2343 and default settings is 32 bit colour. When I change the settings to 16 bit, it still won’t work. I’ve also tried selecting different screen sizes from current default 2048 x 1152 to many others but each time I change it I still get the same error message .
Scan Wise used to work with my old DELL CRT Monitor, I know it’s an old scanner but I used to like the way it worked.
As far as I know Agfa have stopped making scanners, so I must have the latest driver!
Any advise, would be gratefully accepted. Thanx
Thanx to all those who viewed this thread with the intention of trying to help me.
I managed to sort the problem out using the compatability wizard (which I wasn't aware existed).
Hopefully it will contine to work from now on.
I know you've got it sorted now, but if you find the driver software is rubbish, give VueScan a go.. Works with pretty much every scanner ever made, awesome bit of software :)
