Scanner vs Digial camera?
5 Oct 2008
I don't have either so working a bit in the dark but i have been asked to scan some drawings(handmade cards) and put them on a webpage, it's a product, now i could use the scanner at work which i am guessing is a pretty decent one but i would have thought using a good quality digital camera would be a better idea, if the card was set with a screen behind it sort of thing, you would get a much better imafe with a camera than with a scanner right?, well it would be 3d(ish) as opposed to the scanners 2d flat look?
For exmaple you could never get a scan to look this good,
So if you were asked to put a handmade card product onto a webpage for maximum effect how would you do it?
guess it all depends on what dpi the scanner is set to (as well as how good the scanner is)
personally I'd usually scan a document like that just because having shadows and other strange lighting in any photo's of the document I took on a camera would annoy the hell out of me (i have poor photography skills lol)
I'm also agreeing with Spunkey and DJ_Jester, taking a photo just adds that little bit extra depth to things, a photo also I think makes the product look like a finished product because essentially, you've taken a photo of exactly that!
