Scanning problem with 3 of 9 bar code font
7 Feb 2010
I'm having some problems that I hope someone can help me with.
I am trying to scan a series of reference numbers that are all in the following format:
1-000000000-7
When I convert these to 3 of 9 bar code and add the start and end characters it won't scan - if I drop the initial '-' off it works perfectly.
So far I've changed the scaling to 150% and 26pt which scans perfectly without the - but refuses to scan with it.
I've also tried adding '!' as the start and end character instead of '*'
Please can anyone help!
If you pop me a reasonably good resolution image of the code to my trust email I'll have a look at it for you when I get to work. I'll Pop it under a webscan or qc890 or even just have a look to see if the individual glyphs are correct.
