Check the options in the game, the sensitivity is proberbly very low or something, check the options and check the mouse. If none of them work then i recommend reinstalling it.
Looks like you'll need to give the sensitivity a boost, maybe. I have a USB MX510 mouse, works fine. Try looking for updates it's prolly a bug as BigRoger said before.
