So our lawn was 80% moss.. I bought a scarifier/rake (Einhell electric from the rainforest) and applied a liberal amount of 4-in-1 moss killed, lawn fertiliser about a week ago. This could be down for longer but given the amount I put down it did a great job quickly with nightly waterings to drive the chemicals home.
We have some shaded areas and some direct sun areas.
First highest level pass scarifying:
Look at that moss appearing!
Now.. after completing the first pass and manually raking together:
Boot and rake in there for size reference.. this is all dead moss from the first pass only..
Here's the scarifier (top) and rake (bottom) attachments:
Now the next step was to switch over the attachment to rake and give it a once over... lots more moss appeared...
Then switching back to the scarifier again for a second pass at 30deg from the last pass - even more moss..
Now you can see the brown patches of earth minus the moss...
So just having lunch, then second pass rake before aerating with a fork.. and then over seeding with sharp sand and lots of grass seed later on once the sun has dropped.. water... and keep watering each day..
