SCART - Auto channel switching?
31 May 2005
Nottingham
I have an HDMI to SCART scaler which works a treat, however, I have a minor problem.
The remote control for the this TV was broken YEARS ago.
When it is turned on, it picks up the SCART from the STB and auto switches to that channel (no remote control needed) :D
This scaler does not appear to send the auto switch signal so the TV sits there on channel 1 and does nothing. There is no "Input" button on the TV itself.
Is it possible using RGB SCART might help as I understand some devices will only send the auto switch through RGB or vice versa?
