Scart Leads
2 Nov 2006
Leeds, West Yorks.
Just trying to get an general idea as to whether expensive scart leads are really worth the price tag? atm I am using the one supplied with my PVR but looking at various cable shops most scat leads are £30 or so the big question is the average Joe going to notice the difference?
Thanks.
Thanks.
To a point, something around £10-£20 such as a Profigold, low end QED or Ixos etc are all good.
http://www.profigoldcables.co.uk/catalog/product_info.php?cPath=42&products_id=83 for example ?
There is one which comes highly recommended here at around the same price though :)
Scart cables can have quite a noticable effect on picture quality, I bought a QED Silver Refrence scart lead 2nd hand, new they are £60, i paid £16 for it, it made a huge difference compared to the £10 gold plated one I was using before it. reduced picture noise and improved detail.
If you want new then the P21 from QED is also very good, and only around £20.
Of course all this all depends on what you have it hooked up to, but if its a decent setup you should see worthwhile gains.
Thanks for the replys :)
Well I have got Sky HD on order but have and will still use my Thomson DVB TopUP TV PVR connected to a Samsung 50' HD Plasma, I understand the signal carried is analogue so there should be some improvement in picture quality, just need to find the right scart brand :D What's considered the best brand/model to ££ ratio :D
Thanks.
The is the same one I bought for sale on the bay now, just search for QED Scart, its called the QED Silver Reference Sqart AV21 (Fully Wired).
22h left and its at £1.04 :D
failing that just pick up the QED P21 for £20 new
I was very happy with my Thor cable. great picture and build quality.
I've emailed your trust address when you've got 2 ticks.
Andy
