sccm for macs.
3 Dec 2002
Groovin' @ the disco
Hi
Has anyone else started to manage their macs via sccm?
We testing it at the moment, and I can't seem to push out applications for it. It makes the package on the server, then just sits there 'in progress' without going further.
Any suggestions?
Thanks
yes, it is 2012 R2
I've seen the same video.. lol
The windows side of the server works fine.. and the server can see and explorer resouces on the mac, so I can't see it being a permission thing stopping it.
any packages I try to push out just sits in in progress
Have you updated the SCCM distribution points?
In the sense for mobile devices? yes...
or do you have to update the dist point after each package creation?
EDIT: I double checked the settings.. and its working now.. user error obo of someone else... lol
Same as any new package/application you create.. its needs to be distributed to the correct DP.
Also, just to expand on what you said in OP, When you say it makes the package on the server then just sits at in progress.. do you mean it says in progess when your distributing it, or on the report for deployment.
:D This what you were meant to do in the first place! Glad it's working.
= = Casper to deploy iDevice apps. (OSX / iOS) = =
= SCCM to deploy Windows apps. =
Casper cost $$$$$$$$$$
Plus I'm the only mac minded tech here.. this way windows techs can install apps.. and I can sit here doing very little :) win/win
