School me on 3D monitors, please?
26 Nov 2010
Thorne Yorkshire
I've been toying with the idea of getting a 3D monitor. AS far as I'm aware, I would also need to purchase a pair of 3D glasses.
I spent a short time googling and discovered there are a few pitfalls to beware of. Ghosting and crosstalk to name two.
Questions:
Are there any other pitfalls I should be aware of?
Are there different grades/quality of 3D glasses?
Will any 3D glasses work with any 3D monitor?
If web browsing or word processing will a 3D monitor function perfectly ok. E.g. Will there be any 2D degredation if choosing not to use it as 3D?
Thanks for taking the time to read this.
What are your experiences with 3D?
I'd be interested in 1920 *1080 24 inch monitor. Is £330 enough to get decent quality for a 3D setup or is that too low a budget?
there is only one type of glasses for every monitor
its called Nvidia 3D vision (glasses + iR emitter)
you want monitor with high brightness as glasses make it dark
using it in 2D is much better than standard monitor as it can display in 120hz so everything is 2x smoother
also for gaming you need 2x processing power as it has to render 2x more frames
im using this one http://www.overclockers.co.uk/showproduct.php?prodid=MO-021-AS&groupid=17&catid=1851&subcat= as it has high brightness
Thank you. I've seen some 3D glasses made by Samsung (Can't link, I'm afraid) on another site but I'm not sure if they work with other makes of monitor. 2D operation sounds good. Thanks for the brightness tip as well. Twice the processing power required by my gpu? Sounds obvious now you mention it but I hadn't thought of that.
If I wanted to retain my current fps rate then I'll have to consider a gpu addition too. Hmmm, food for thought. Thanks, z10m.
samsung glasses that you've seen are made only for 3D TV's for 3D monitor you need nividia glasses
You saved me from possibly making a costly mistake there with those Samsungs. The price of a monitor, glasses and maybe another gpu is making me think twice now. It all adds up, and I'd like good quality images when I do go for it. I see now that will cost me a lot more than I originally guessed. I'd best wait a while and see how prices develop. Thanks again.
i believe the main benefit is playing games at 120hz for the smoothness and not the 3-d, i hate v-sync but i have to have it enabled because otherwise i get horrible screen tear but then again my monitor is not very good.
Hi BadBloke,
I'm going through the trials and tribulations of 3D set-up myself at the moment. Fun isn't it? :rolleyes:
Firstly what are you looking to do with your 3D set-up? Is it mainly for gaming, movies, application etc.? Let me know and I'll try and help you a little further.
Currently manufacturers employ a variety of different methods to render a 3d image to the viewer. Even manufacturers that use the same 'method' will require you to have glasses specifically for their device as they will tune them that way. There is good news however. http://www.4rfv.co.uk/industrynews.asp?id=123612
You're at the cutting edge of 3D; the first generation proper, as it were. Think of it a little like deciding whether to go for Betamax or VHS back in the 80's. The difference between the 80's and today is that there are many more varieties of 3D technology than there were video playback technologies back in the day, thus making the chances of you backing the future-proof one very remote indeed. On the plus-side though, you get to play with technology that most people havent even considered for their own homes yet. It may well, if history is any indication, inevitably be a wasted investment as the technology develops.
Enough waffling from me, time to answer what questions I can for you.
In a perfect setup you would never get ghosting or crosstalk because the screen would have lost it's image before the next is projected. TV's tend to suffer with this much more than monitors in my experience. Particularly the large screens; your 50" LCD's etc.. A good gaming monitor like the Benq 24"'s are great in my experience (I just bought the120hz XL2410T and I'm gob-smacked by its picture quality).
I think I answered that question above but to clarify; Each manufacturer will produce glasses for his device. Sometimes different product ranges from the SAME manufacturer will be incompatible. It's a minefield, quite literally. In short though, for PC 3D there are 2 main formats currently. Nvidia has a solution that involves a transceiver and active glasses and AMD have a solution that theyve handed to their partners whereby the partners will develop the tech and AMD will develop the software (drivers) for that tech.
In general and when referring to TV's specifically, there are probably differences in the manufacturing processes and the quality of materials etc., but I assume youre referring to the 'quality of image' when you pose this question as opposed to 'Can I trampoline on the headset, feed it to my dog etc. and expect them to still work'.
Answered above :)
Absolutely not! If anything your 2D expereince will be enhanced. Your desktop will be smoother, your mouse movements smoother, even your wife/girlfriend/hamster may be smoother....
I have a 24" 75hz HPwp that I have loved the last 3-4 years right next to my new shiny Benq. It's very noticeable how much better the 120hz monitor is, although I doubt I would have known had they not been side-by-side.
£330... hard one. With some specials you might get to that price-point. The PC solution thats out there right now, Nvidia, is around £120 plus the monitor (Benq XL2410T) @ £282, making a whopping £400 outlay. That said, 3D tech will drop in price as more manufacturers come to market. There are definitely alternative displays out there but my experience is with Benq. After much research and deliberation, they were who I plumped for as they gave me the most bang for my buck.
I hope the information was useful to you and please feel free to message me if you wish to discuss further.
Eastidious,
I'm very sorry for the long delay in replying.
Thank you very much for such a useful and informative reply. Very helpful.
I've decided to leave it be for the time being. Costs and early adoption being the two main reasons.
I'll be keeping an eye on how things develop though.
Thanks again.
I went 3D a couple of months ago. Biggest waste of money ever.
It's nice, don't get me wrong, but not worth the sort of money it costs. I'd sell up if it wasn't for the fact that I actually really like the monitor and can't be bothered with the hassle of selling it and the glasses, then replacing the monitor, all to bag me £50 (after shipping etc. I'd prob only get about £250. A comparable 24" monitor would set me back£180-£200!). I'm annoyed with myself for getting caught up in the hype for 3D, the money would have been better spent on a better GPU or a 2600k. I'd rate 3D as being worth maybe £50? ceratainly not the £hundreds it costs.
