- 24 Apr 2011
Okay so I was looking to upgrade without buying a new PC, I have an i5 2500k with an ASUS P8P67 running with the stock cooler and stock settings, so the cheap no brainer upgrade was to buy a custom cooler and overclock it to hell.
I went with this cooler: http://www.overclockers.co.uk/showproduct.php?prodid=HS-061-ZA
Now I know what youre thinking, and yes I did measure up my case before hand to ensure this beast of a heatsink would fit in my case, and it would, just about. What I didnt allow for was the fact that my case fan is right above my CPU! so when I tried to put everything back together the damn case fan wouldnt let me put the side panel back on. So, I decided to try without the case fan.
My question is, will the lack of case fan make much difference? Ive switched everything back on and ran everything idle for a while, and the processor is running at around 23C, which is pretty good I think, Ive never overclocked stuff before and would like a vote of confidence before I try it.
The other issue I had installing this was a design flaw. there are four bolts you have to tighten, and if you look at the P8P67 design, theres a couple of heatsinks next to the CPU which, when the Zalman cooler is in place, makes it virtually impossible to get to one of the bolts to tighten it properly. So 3 bolts are tightened properly and one... Well.. Isnt. Id like to say it was relatively tight but to be honest I just turned it around as much as I couldwith my finger and thats all I could do. Do you think this might cause any issues?
Might have to do some tests at stock settings before trying to overclock.
