I can't help but I'm sure someone will be along with an Oracle of wisdom soon enough.
Other half has a question about planning an experiement for determining the concentration of NaOH.
She has to plan two methods one of which is titration, the other she has to work out.
Any pointers, she'd be very grateful.![]()
Titration is the only thing I can think of to work out the concentration....
Whats HCI?
If you have the pH you can work out the concentration.
on the same note as the HCl route you could precipitate an insoluble salt of sodium (since NaCl is water soluble).
hmmm, let me think......i don't think that will work as there are so few insoluble sodium salts, may have to scratch that idea.
ermm, measuring the pH is the obvious answer - i assume you want a chemical method??
how about, you add some iron (III) chloride - i think the insoluble iron hydroxide should form which you can filter, dry and weigh and work out the no. of moles of hydroxide that way.
OK, thanks for the methods. Re the HCI route, she is asking:
if I used 25cm cubed of NaOH, what would be a sensible amount of HCl to use...should I add a pH indicator and stop adding the acid when the colour turns green (neutral)? And should I just filter the result or heat it and let the salt crystalise?
