scirocco front pad change
Man of Honour
11 Dec 2002
Darkest Norfolk
Hey guys, anyone know which bolts you need to remove to swing the caliper round on the scirocco - can't get me head into the wheel arch well enough to see and far to cheap to buy a manual :D
a guide would be amazing, but can't seem to find one :( its on a '92 mrk2 scalar
cheers
Sam
Unbolt and remove the bottom bolt and slacken the top one. This will allow you to swing the caliper upwards.
Then, just use a piece of string and tie it to the suspension or something to stop it from falling back down.
:cool: nice one - thought it was thouse, but the bolts were damn well stuck and i allways get kinda worried about hitting anything to do with brakes with a hammer :)
