Hi there.
First of all I am very new to Linux and the problem I have is I think beyond me for the moment.
Basically I run a Distributed Computing project called Folding@Home on Ubuntu Edgy [6.10 AMD64]. In order to monitor my client's progress I am trying to install a small utility called FahMon, however I am being thwarted by a possible wxGTK issue.
I downloaded and installed wxGTK-2.8.0 using the following commands:
After that I used the command wx-config --list as a means of testing if it installed. The output is
Now, the next step in installing FahMon [Exact file is here [src.tar.bz2]]is to go into the src directory and run scons
Unfortunately this process is terminated due to errors relating to wx components. The full output is as follows:
I have asked about this on the wxWidgets forums but so far I haven't discovered anything. As per the title it could be either wxWidgets or Scons. Any help in shedding some light on the cause of this error would be great.
SiriusB
Code:
mkdir buildgtk
cd buildgtk
../configure --with-gtk --enable-unicode
make
sudo make install
sudo ldconfig
Default config is gtk2-unicode-release-2.8
Default config will be used for output
scons: Reading SConscript files ...
scons: done reading SConscript files.
scons: Building targets ...
g++ -o clientDialog.o -c -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -pthread -pthread -O2 -D_FAHMON_LINUX_ -Wall -Wno-strict-aliasing -I/usr/local/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/local/include/wx-2.8 -I/home/aeternum/Downloads/FahMon/include clientDialog.cpp
clientDialog.cpp: In constructor 'ClientDialog::ClientDialog(wxWindow*)':
clientDialog.cpp:68: error: invalid use of undefined type 'struct wxButton'
/usr/local/include/wx-2.8/wx/sizer.h:23: error: forward declaration of 'struct wxButton'
clientDialog.cpp:83: error: invalid use of undefined type 'struct wxButton'
clientDialog.cpp:85: error: invalid use of undefined type 'struct wxButton'
scons: *** [clientDialog.o] Error 1
scons: building terminated because of errors.
SiriusB
