Scottoiler installation questions
2 May 2004
Hello!
I ordered the Scottoiler v-system earlier today so should get it some time this week and hopefully install on the weekend.
Do they come with everything you need to get going? Specifically priming tubes, etc?
Also, it mentions using RTV Silicon Sealant on the vacuum threads. Does it come with that? Will PTFE tape do (they stock it at my local Halfords & it's cheaper so would be ideal)?
Thanks.
They're really good instructions, lots of info, but just doesn't mention if it comes with the priming tube and RTV sealant unfortunately :/
I think they do. When my best mate rode bikes he had a SO. Swore by it and I don't remember him having to buy extra parts to get going.
Have you looked for 'unboxing' vids on youtube?
Moredeath13 has one
Ah good idea, didn't think of videos for some reason! The one above is for the e-system, but have found some v-system one which are helpful, thanks :)
Found this awesome video if anyone else is in the same position as me:
. Also it's on a Hornet :D. Granted, a new one, but very similar to mine.
Clears up everything really. Explains the whole installation process in simple steps, easy to follow :). Cut into inlet pipe, put the T shaped thing in, attach the Scottoiler pipe, mount Scottoiler, done. Their instructions recommend silicon sealant to ensure an airtight seal, but they don't use any in the video. Might get some anyway. £6 for a tube which I'll probably only ever use once though :/
Really really well. It was one of those jobs that takes a while, but absolutely nothing went wrong or didn't fit, a really enjoyable job :)
It's under my seat nicely. I found a piece of that rubber cord stuff that holds stuff down not doing much and the oiler itself slotted in perfectly, almost as if the bike was made for it, it was slightly curved and everything.
Routed and stuck the tube to two places on the swingarm using the sticky clip things they provided. The little cleaning cloth they give you cleaned it amazingly well (wish I had a huge cloth of that :p). It came down through a perfectly placed gap under the seat that leads directly to the swingarm.
The main bit I was worried about was the inlet manifold connection, cutting into it etc. but it turns out my bike has a 'spare' inlet manifold covered by a small screw on the left side. Screwed the spigot into there with some gasket sealant, popped the L shaped connector on and routed the tube really nicely alongside some cables under the tank (didn't have to take the tank off).
The longest bit was taking the axle out to attach the bracket that holds the feeder thingy, but I'm glad I did that as it forced me to full re-adjust the chain and gave it a really good clean at the same time. Had to kind of sit under the bike and support the wheel with my legs so I could pop the axle out, put the bracket on and axle back in without having to mess about with the really awkward washer that likes to fall out just as you get the wheel lined up.
I currently have the flow rate on almost full, but have spoken to the Scottoiler guys who say that's quite normal for the cold weather. I expect I'll turn it down a bit this week with the good weather here.
Really impressed with the thing, although it still doesn't quite reach the other side as much as I'd like. It probably does enough to stop it going orangey brown, but I'd like a bit more oil on there.
I spoke to the Scottoiler guys about it not reaching the other side as much and they recommend the dual sided feeder for the all weather rider. I had a look and it's even easier to fit, you clamp it to the swingarm and it goes either side of the chain and you're done, so you don't need to mess about with the positioning on the rear sprocket. I'd recommend talking to them and see if they'll do you a deal and include just the dual sided one instead of the single sided.
Would highly recommend it. Love mine, worth every penny. So nice to put the bike away and not worry about it. Just need to check slack and flow rate every so often.
I'm quite proud of my mostly stealthy, neat job :)
a lot of places are doing a free dual feed at the moment. I did wonder if that was going to be the problem with feeding just one side.
I currently use Wurth chain lube but find it still lets the chain rust :(
I have moved from Wurth, whilst good for track bikes, road bikes it is not.
I now use WD40 Chain Wax, not the lube.
It's heavy, sticks really well and only sprays a little if you properly wipe the excess off. Keeps the chain nice and lubed for a long time through all weathers!
Paraffin and a rag, tis what I use to clean, then a spray on top, under and both sides of the chain until heavily coated (holding a rag the opposite side of the chain to stop spray) and then a good wipe down so very little excess is there.
There will be some excess between links but if you're doing it on a warm chain (best practice) it will work it's way in and you will get some but not lot's of spray. Did mine weeks ago. Will do it again before the weekend mind you.
Mine came with almost everything.
However, I did need to order an extra bracket in order to reach the rear wheel at the angle I needed. Sort of a drop down and tuck under affair to skirt around the sprocket bolts. Took a bit of trial, error and replacing of chewed-up dispenser tips before I found a good setup.
Doh, wish I had looked out for that!
I'm not a fan of Wurth at all anymore. I used to think it was good, but then my chain started to rust despite looking after it and regular lubing. Same on my brothers Bonneville. I also find it quite expensive, to keep the chain properly lubed I seem to go through a lot of the stuff and it's now £10-12 a bottle.
Got a free can of the WD40 wax which I used on the hire bike I had for a while and was really impressed, held up really well in that terrible rain we had a few weeks back. I ended up applying almost the entire bottle (it was a small sample one) so the chain had a full coating of whiteness. Didn't touch it after that, no fling or anything.
Scottoiler even better though :p. I've read some bad reviews just now on the dual injector, so might stay away and just manually put some on the other side every month or so to keep the capillary action going. It's not at all bad and I think it'd be fine left alone as it is getting a bit of lube on the other side, just not as much.
Had to reduce the flow a fair bit today. The weather does change the thickness of the Scottoil quite a lot!
TBH I find that just with the oil applied to one side of the chain it works its way over to the other side well enough.
True, it's just a little uneven. I've been running mine for just over a week now which is about 200 miles and the chain still looks like I just cleaned it, on both sides :D
Looks like it got rid of a kink as well. Wish I had never used Wurth (which caused a couple of kinks), it's just not good enough for an all weather rider. I suppose if you apply it after every ride it might be ok, but honestly who's going to do that? That would be expensive and annoying.
Got me a can of wd40 chain wax from Halfords for £7.99 with trade card! Hopefully it's an improvement on the Wurth stuff.
