HI all,
My old, now my wifes computer, looks to be coming to the end of its natural. It now has a trojan on it which has prompted the review. You have to give it a good wallop on top to open the DVD drive and its connection to the internet is unreliable. Its running an old SP of XP
It has a MS-6777 Mobo and a 230 PSU, 1gb ram. It has an AMD Athalon xp3000+ at 2.16Mhz
Does the Mobo support enough newer technology to bother to upgrade wipe and reinitialise it with Vista or 7 or when you can get a desktop for 250ish (Though 250 is a lot of money right now) with windows 7 that is perfectly adequate for very basic stuff and web browsing is it just a waste of money when its so old and will not be fit for any purpose soon.
Thanks.
Thanks.
