Scratched Cpu water block, affecting temps?
5 Apr 2008
I noticed that my cpu block waws scratched in a few places.
I have a triple radiator only cooling Q6600 go at 3.6 ghz with 1.5v in bios. Temps get to mid 50s at load after a while.
Is that ok? When all is at stock voltages and clock speeds it is at 33 load
Real Temp
You could get better temps if you lapped the block and cpu but i wouldn't bother seen as them temps aren't anything to be worrying about.
What programme are you using to check your temps!
I had my Q6600 @ 3.2 and my load temps were around 59c - 66c dependent on room temperature.
This was usng the Swiftech Dual Rad.
