Just got a new Q6660 to replace my ageing E6300. Kinda confused on the overclock. Easy clock to 3.GHz via fsb@333Mhzx9 multiplier route but problems when clocking to 3.2Ghz via 400fsbx8multiplier. The boot up and windows are running fine but when i try to benchamrk using 3dmark 06, my FPS is drastically reduced. I remember having the same problem with my e6300 but the solution for me was to bump up the PCI-E frequency to 110. Now i have tried doing the same but to no effect.
Running the following at the moment.
Asus P5B-E plus with latest bios (can't remember the version no.)
All software up to date as they were with the e6300.
All the usual cpu throttling things are disabled.
Vcore@ 1.4v in bios but cpuz reads it as 1.34. Temperature on all cores ranging from 38-42 idle (warm weather in room).
Volts on [email protected].
Ram timings: Slack to begin with. 5-5-5-15
PCI thingy pegged@ 33.33mhz with PCI-E frequency @110.
Fsb volt at 1.3v with NB volts at 1.2v (no fan on it)
Any ideas what might be causing the slowdown in fps?
Just to recap: @3.GHZ everything is fine. 3dmark giving me just over 14k.
Thanks in advance.
Thanks in advance.
