Screen capture
20 Mar 2005
Leicester
been using fraps but it doesnt work with eyefinity atm, only caps half the screen.
Any freeware or cheap screen capture software that will alow me to take captures at 5740x1080
thanks
camstudio or hypercam are pretty good, although you need a hard drive that tops 300MB/s write speeds to capure at that resolution otherwise recordings will stutter heavily
thanks for that im not after video recording at that res just screenshots, if i record I drop to single screen :)
will check those two out thank you
Haven't you answered your own question then?
Won't Printscreen do it?
i find that in games and some programs printscreen only comes out as a white screen.
I know that dx10 games come out black or white in print screen on high resolution.
