screen cleaning help
1 Mar 2024
Leeds
So my darlin of a sister as got what i think it ink on my screen and I've tried to clean it with water, window lean and furniture polish.
what sort of cleaners can i use, i don't want to mark the panel
ink is about 5mm x 30mm
isopropyl alcohol is your best bet.
Dampen a soft cloth with isopropyl alcohol and
Gently rub the stain with the cloth until it disappears.
Wipe the screen with a dry cloth to remove any residue.
Don't use isopropyl alcohol it can damage the anti reflective coating on the screen.
You can get cleaning spray specific for screens so you are best sticking to that if you do not want to damage the screen.I use "screen mom" which is pretty good but never had to try and remove an ink stain.
