Screen flicker @140hz
22 Nov 2021
Jersey
Monitor im using is 144hz, since I built a new pc the other day, I can now fully use it at that rating, go to windows and put that as the setting, however, every once in a while there is a flicker at the top of the screen, not all of it, and it isn't constant but it occurs temporarily
I'm running a 3080, 5800x so that shouldnt be a problem, of course using dpi connection for the 144hz (2nd monitor is hdmi @60hz) monitor im using is AOC C32G1 32"
Is you monitor a G-sync just a question, as for your problem try change the DP/HDMI cable over if you got one!
