screen flickering
10 Aug 2004
hi my acer laptop screen lcd is flickering but when i plug it in a monitor it stops flickering but some of the screen got green places is there a way to fix it the model name is acer aspire 5652 :(
________
VOYEUR RUSSIAN
if it is fixable i dont think its something you could do your self. it could be *** actual screen or the inernal connector cable that runs from monitor to gfx out put internally
:)yea but i think i found a fix not sure i looked on google and found that the inverter is making the prob maybe:confused: 25? they go for just looking for more info to see if it is that
________
Mazda atenza picture
I get this at work when building Dell laptops, some of them come in and the screen is fine until it is unplugged from the power adaptor. We just send them back, however it seems to be an internal problem of the laptops as it makes no odds what adaptor is used. this may be a similar thing, although i havnt tried a faulty one with a separate display, id say its an internal connector is borked. is it still in warranty? i hope so =/
- Pea0n
