19 Oct 2011 at 21:23 #1 Suspect13 Suspect13 Associate Joined 10 Sep 2011 Posts 25 How do I stop i flickering. Its really annoying as it goes from middle to the right hand side of the screen. Its a 27 dell sharp screen.
19 Oct 2011 at 21:58 #3 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 There's an edit button for your typing mistakes. I assume this is a 2560x1440 resolution monitor. Are you using the dual link DVI cable which should have been supplied with the monitor?
