Screen goes black for a few seconds when alt-tabbing for example
26 Jan 2005
Hi,
I've had this annoying thing for the last couple of driver releases or so.
Basically if i'm in a game and I alt tab or even just locking my computer, the screen goes black for about 2-3 seconds and then the picture of the desktop or whatever reappears. The same then happens when I go back to a game or unlock my desktop.
The desktop is at 1920 x 1080 120hz as are all the games I play.
So why does it do this? In the past it used to do it seemlessly with no black screen at all?
Is there a setting I can change to make it behave like before?
Thanks in advance :)
Does it with my 6970 aswell. Dont think it is a major problem. Most likely just windows lagging. If it is really bothering you do a reinstall but atleast defrag the hdd
is it a setting in UAC, read somewhere you can stop it dimming the screen
control panel/user accounts/change user account control settings and drop the slider down one step and see if it fixes it.
