Anything in event viewer?
Don't suppose you can check the graphics card by using built in graphics on the motherboard or swapping the card.
I assume you've already checked your power/sleep/hibernation settings.
Does it do it whilst gaming (OpenGL/Direct3D type stuff), or when just operating normally?
Don't ever fear the Windows Updates. If there's a problem they fix it rather quickly.
Have you done a system restore to before you updated?
If you mean it goes black for a couple of seconds and the comes back mine does the same. No idea what causes it. Using Win8 but never seen it in win7.
i have this issue on my laptop which has windows 8 pro. the screen randomy goes black, i haven't found out why yet
nope.Have you got firefox ? could be same problem i have been having.
