screen going blank
  • Thread starter Thread starter Ish
  • Start date Start date
Ish
Ish
11 Jan 2006
West Midlands
Hi
I have a problem with my pc in that the screen goes black at random times and then then you have to reset the pc to get it going again.
This happnes whether I use the onboard VGA or the output from the AGP card.
What should I be testing/trying? :confused:
onboard & AGP drivers are the latest & the card is seated properly.
what are your specs? What OS?
you could try looking in the bios for memory timings/ram voltage/cpu settings
these could have triggered the black screen.
It's just a basic socket a sempron system that my kids use. I don't think any bios settings have been changed but I will reset then to defaults anyway just to make sure.
