Screen recording in Mavericks
21 Oct 2002
UK
Hi all,
I am trying to record some gameplay footage on my Mac. I can use the quicktime screen recorder with no massive loss of framerates. However, I can't seem to figure out how to get sound to work on it. The only options I can see are no sound or sound from the inbuilt microphone so it only records external sounds.
Is there a way of fixing this and if not is there any other software you can recommend that I can use?
NO! Stay away from those options!
Just use Telestreams Screenflow! It's amazing, and has no real impact on FPS at all.
It's also a video editing package so you can do it all in one package.
It also supports multiple sound inputs. It'll record game/system sound on a different track compared to the mic you use. It'll also record a webcam if you have it.
Everything on my channel is recorded using Screenflow.
https://www.youtube.com/user/N19h7m4r3
Stay the hell away from soundflower, snapz, and camwtist, they've caused nothing but issues and kill FPS. Same for quicktime.
