Screen Resolution Help
7 Apr 2004
Hi,
Im trying to get my widescreen monitor to work at its native res of 1440x900, I have installed the nvida drivers, and im using a 7800GT, my xorg.conf is below, any one got any ideas on what I have done wrong? In display manager the max res i can select is still 1024x768.
Code:
Section "Monitor"
    Identifier     "My Monitor"
    HorizSync 30-82
    Vertrefresh 56-76
    Modeline "1440x900" 106.5 1440 1520 1672 1904 900 901 904 932 -HSync +VSync
EndSection
Section "Device"
    #VideoRam    4096
    # Insert Clocks lines here if appropriate
    Identifier     "VESA Framebuffer"
    Driver         "nvidia"
EndSection
Section "Screen"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
#   DefaultDepth 8
#   DefaultDepth 16
#   DefaultDepth 32
# "1024x768" is also a conservative usable default resolution.  If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
    Identifier     "Screen 1"
    Device         "VESA Framebuffer"
    Monitor        "My Monitor"
    DefaultDepth    24
    SubSection     "Display"
        Depth       8
        Modes      "1400x900" "1024x768" "800x600" "640x480"
    EndSubSection
        Depth       16
    EndSubSection
        Depth       24
    EndSubSection
        Depth       32
    EndSubSection
EndSection
Thanks for any help,
Jack
