Screen Resolution won't change
26 Oct 2006
Turned my pc off earlier this evening and there were no problems at all, however now just turned it back on and the screen resolution has changed from 1900x1200 down to 640x480.
No idea how this has happened so just tried to change the resolution back to 1900x1200 and it seems to attempt it, screen goes black etc and it comes back saying would i like to keep the new resolution. Yet it has actually still stayed at 640x480.
I've downloaded the latest drivers for my graphics card (8800GTX) again and still not fixed the problem, restarted the pc, tried a system restore back to yesterday but nothing has worked so far.
Anyone else got any ideas please ?
Boot into Safe Mode, remove the graphics card in device manager - check add / remove progams in Control Panel and remove any software related to your graphics card. Might also be worth checking what you have in the Monitors section while your there.
Restart the PC and try re-installing your graphics card drivers...
