Screen resolution won't fit my screen?
24 Jan 2014
I brought a benq gw2760 and the screen resolution dosent fit my screen for windows? The screen is a 27 inch but it leaves a black outline on the windows screen. I have adjusted the screen to all resolutions there all either to small or to big!
Anyone know a fix?
Hi,
What graphics card are you using?
Make sure scaling on the monitor is to the max.
Like this: -
This is likely due to underscan. Tends to happen to me when using HDMI with AMD drivers. Open up the Catalyst control Center, go to my Digital Flat Panels, select scaling options, and set the under/overscan to 0%, or whatever happens to fit your specific monitor best.
Give it a try and let us know.
I had a similar problem to this years ago with an old computer. If I remember correctly, I managed to sort out my problem by simply installing an older version of the graphics card driver.
How are you connected to the monitor? Am I right in saying this has either VGA or DVI input?
If so have you tried both?
