Do you use an AMD card? I was having this an awful lot with video playback to my TV. I fixed it by setting the TV as my main display rather than duplicate or extended. This resolved the issue
You issue may be totally different but its worth a shot if you configuration is the same.
It's a common problem with AMD, if you use different outputs for each display i.e. one on HDMI one on DVI, you will get screen tearing because it can't sync displays across interfaces.
