- 24 Feb 2013
Hi,
I've been experiencing major screen tearing in both Bioshock Infinite and BF3. It is more like a wave of screen tear traveling vertically down the screen when looking around (none when on a static screen) - sort of like interference? There is no other performance loss bar this. The issue has started fairly suddenly, as I have been able to play both games without noticing anything like this before.
Obvious question is what have I changed since playing the games with no issue - I have been playing with a small CPU and GPU overclock but am still experiencing the same after resetting the BIOS and setting the GPU back to it's stock clock. I have also installed an NZXT LED cable w/ controller card, which I have removed the power for and tested for the issue again. The issue persists.
My graphics card is a Sapphire 7870 XT, which i've tried reseating and power connections, etc. I have a global frame rate limiter set by MSI Afterburner, originally set because I was getting loud capacitor whine on some game menus.
Any suggestions on why this could suddenly occur and the best thing to try next?
because without a display and gpu being in sync they will be out of sync and you get screen tear.
