Probably a shout for Mr Bigredshark but I have a client who has a SSG 140 that I've been asked to remote into and have a look at.
Can telnet just fine, but using Putty on Windows after the login prompt none of the text gets printed to the screen, though the keystrokes are registered as I can enter commands.
Using terminal.app on my Mac I get text but backspace doesn't work.
Seems a bit strange as I use both methods to connect into various different Juniper and Cisco bits of kit and have never had any problems like this.
It's running Firmware Version: 5.4.0r1a.0 (Firewall+VPN) but I can't find anything about this in the release notes.
Going to be a bit of a PITA as they don't have a support contract for it anymore and I can't get a newer version of Screenos to stick on it :S
