Screw Cases
Awsome thanks
I was going to get a stacker until i saw the screwless slots
and it seems every other case i've looked at seems to use
them as norm now.
I done a review on the Enermax CS-718 for my site and that has screwless fittings.
But the holder can be just removed and the fan just screwed on.
Simple.
MC_Bob
I find that the pins on screwless cases can't hold soft antivibration
mounts and the drive falls out if you move the case.
i had to cabletie my zalman HDD cooler in my current case to stop it dipping down at the sides.
