Screw Down CPU Cooler
19 Sep 2011
South Wales
I'm looking for a CPU cooler which I am able to screw down, my motherboard doesn't fit the push plugs. I have a LGA775 socket, help?!
Thanks
Out of curiosity why don't the push pins fit your motherboard?
The motherboard I have is one which came with my 2 year old computer, its one of HP's and for some reason the holes are just too small.
Got a budget in mind? Cheap as possible? Or looking to heavily overclock?
EDIT: I *think* this is screws - http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-CS
See here - http://www.corsair.com/media/cms/manual/Corsair_A70-A50_Mounting_Information_-_Intel.pdf
Thanks for these, I'll look into it. Don't really have a budget just want my computer to run properly, two out of four screws have broke on the one I have now.
Are you sure that there isn't just some sort of removable backplate on the motherboard which protrudes through the holes making them smaller?
zalman coolers come with the screw down type think ive got a complete kit lying around going for much cheapness trust me and i will give u some more info if interested :)
@ scottmuir424
That appears a very poor attempt at disguising the offer of an item for sale outside of the Members Market.
Perhaps you should have a re-think about leaving that post in place.
how do you do this then i will gladly make a thread up in the MM if OP is interested just trying to help a fellow member didnt think i was being underhanded and apologise if it came across that way
Yep! those are my pictures and I just saw the other thread about it, I'm gonna try and take the motherboard out and see if it comes out...
