Screw Removal - Antec 902
14 Jan 2009
Manchester
Okay so my antec 902 arrived this morning, i have succesfully secured the PSU and now i am onto the motherboard, but oh wait, problem. Antec secured a box of screws into the case by screwing them on, and i can't for the life of me get the screw out, as the screwhole is needed for the motherboard risers. Help Please:)
Then you have to get it out! Anything else will likely damage the thread.
Try giving it a slight tighten first. Then it should be easier to unscrew.
Received my 902 this morning too :)
Really like it. :)
Is it me, or is there virtually no difference in sound levels with the top fan on low or medium? I can feel more air being pushed though..
Really like it. :)
I hadn't noticed but just tested, appears there is no difference. Im more concerned with the fact 2 of my motherboard screws keep falling out and are not tightining at all. Think im gonna have to find some old spares :(
Did you not get loads of screws with your case (inside the box with the bay adapter)?
I used the same type of screws that the PCI-plates use, not the thin small ones that are used for DVD-RW's/HDD's.
Sorry for the bump, but I've found out I used the screws to mount the motherboard which are actually for the DVD-RW..
It's almost impossible to get them out once their in unless I manage to pull the standoff out, and found the screws for the PCI-plates work fine. Are you actually meant to use these?
I recently upgraded to the 902 and was quite simply the best upgrade i have done the temps in my old lian li were ridiculous. It seems that i had exactly the same problem where the screws i used didnt like the antec standoffs was quite annoying. Seems im not the only 1 thats had this problem. Although i thoroughly pleased with the case. Everyone thats seen it thinks its awesome. Great case IMO.
