Screw Size On Wavemaster
Suspended
12 Dec 2005
Leeds
Anyone know the torx size i need to open up the wavemaster? I tried the various allen keys I have around and none of them work!
Ahhh the same as on the 201's.
My window lock allen key works for them, do you know how I can find out what key it is?
(My skills with tools are not too good ;))
managed to take the case apart without needing to open the screws, i thought i needed to open em to get to the front fans but all i had to do was unscrew 4 screws near the fans an 2 on the base and voila the front panel came off, the case is in pieces now, taken everything out and all the parts off, and now i cant be bothered putting it back together again
