Did the title grab your attention
My PSU came with an anti-vibration dampener and I wandered whether when you secure the PSU, do you tighten it as much as possible or just enough to hold it securely?
I've been getting a slow rhythmic humming noise from my case and after checking everything in it, the only thing left that could be causing this noise is the PSU, so I want to make sure it's fitted to get the maximum effect from the dampening material.
TIA, dagwoood
TIA, dagwoood
oh & the tighter the better.
