Screwdriver suggestions
29 Dec 2012
Hi Guys
I know this may be a bit silly but im looking to get some new screwdrivers after mine kept getting borrowed and not coming back, I now have the odd one left.
I don't know what brand quality is like now so I don't really know what to get, I was thinking Stanley or Daper. I need a few but I dont know if i should get a set or buy 2 for now.
I need both the standard and some also Precision one, I'm not looking to spend too much because they don't get used often.
Not sure if allowed to link so google -
Draper 5776 Interchangeable Insulated Screwdrivers (18 Pieces) -
£32 for set with precision and power handles - has ph and pz 0 sizes which come in handy and star bits for appliances
Found quality of these just as good as wera but much cheaper - never snapped or broken except when i put into a drill without clutch set and that was my fault lol
For £30 you can get 2 Wera sets (standard and precision at around £15 each).
Halfords advanced screwdrivers are good for the money, but often on offer when they are much mor reasonably priced (the £20 set is often less than £10).
Stanley are ok if the Fatmax range, but some of the standard Stanley stuff is dire.
I'd avoid any set of 10000 screwdrivers for £10 and just get a quality set of 6 drivers you will use and a seperate precision set.
Another one for Wera but buy a set - I bought one screwdriver a week and cost much more in the end.
Lidl are doing the yellow and red insulated screwdriver set for a fiver at the moment. Good quality and great value for money!
