Screwless switches and sockets
27 Mar 2013
Has anyone much experience with these, I've fitted a couple but as its a metal plate clipping onto a plastic back they just don't feel very solid. Am i doing something wrong or is it just a flaw in the design?
Fitted 100s of these never had a problem. Need to ensure the plastic back is level or the metal face plate wont clip on correctly. Sometimes the backbox needs switching out for a deeper one and if your converting from plastic switches you need to ensure your new ones are earthed properly.
Cheers, i did wonder if it was to do with the backbox. The under part that gets clipped to i think is quite flexible so probably moulds to the wall better.
