Screws for fan/rad
13 Oct 2009
I want to move my fan to the back of the rad to push the air through the fins.
How do I mount the fan and the rad to the back of the case? (Asetek 510LC)
The screw holes on the fan are shrouded, so I can't use two sets of screws. Can I get a set of longer screws that will go through the case, fan and into the rad?
Yes, measure the lenght you need, google ballsfasteners > its fleabay, l get all my bolts from him, service is very good, cheap + free post 2nd class. Depending on your screw size the last lot l bought was M4X35mm -20 pack > £2.89. ;)
or get them from a shop that sells screws.
i go to a shop near me for all my rad screws and there something like 5p a screw
that the screws you have in and tell them you want same thread but what ever size longer
