Script for WinCE?
29 Sep 2006
Hello all,
Firstly, I should ask you to please bear with me, as I have no knowledge of programming and my understanding and terminology is probably flawed. However, I am wondering if this is possible...so...
I need a script of some sort that incorporates a shell.ini file to go on the root of an SD card, which when accessed on a mobile device (a Navigo) copies certain files from the SD card to an Applications Data folder on the WinCE device before launching an .exe file on the SD card.
I'm googling all this just now but I'm not really sure what to look for, whether it's an easy thing to do or indeed possible at all!
Thanks for any help/advice!
