Script to remove user profiles / Ad accounts and Home Directory
19 Jul 2006
OK So Im Testing this code
Code:
$users = Get-ADUser -Filter "*" -SearchBase "OU=Class 2013,OU=Students,DC=School,DC=local" -Properties samaccountname, HomeDirectory, profilepath
$users | ForEach-Object {
        #delete home directory from server
        remove-item $_.HomeDirectory -recurse -force
        Write-Host 'Home Directory: '$_.HomeDirectory
        #delete profile folder from server, delete line if not needed
        remove-item $_.profilepath -recurse -force
        Write-Host 'Profile Path: '$_.profilepath `n
        #delete user account from AD
        Remove-ADUser -Identity $_.samaccountname -Confirm:$false
        Write-Host 'SamAccountName: '$_.samaccountname
Profile Path is \\MainServer\Pro\%username%
Home Path is \\MainServer\HomeFolders\%username%
This is in a test environment so its safe to mess about.
This script throws up errors.
It does delete all the selected users from the AD
it does not delete there profile or Home directories
Code:
remove-item : Access to the path '\\MainServer\HomeFolders\cice\Documents' is denied.
At C:\bin\Remove-Users.ps1:8 char:9
+         remove-item $_.HomeDirectory -recurse -force
    + CategoryInfo          : PermissionDenied: (\\MainServer\HomeFolders\cice:String) [Remove-Item], UnauthorizedAccessException
    + FullyQualifiedErrorId : RemoveItemUnauthorizedAccessError,Microsoft.PowerShell.Commands.RemoveItemCommand
Home Directory:  \\MainServer\HomeFolders\cice
remove-item : Cannot find path '\\MainServer\Pro\cice' because it does not exist.
At C:\bin\Remove-Users.ps1:12 char:9
+         remove-item $_.profilepath -recurse -force
    + CategoryInfo          : ObjectNotFound: (\\MainServer\Pro\cice:String) [Remove-Item], ItemNotFoundException
    + FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.RemoveItemCommand
Profile Path:  \\MainServer\Pro\cice
SamAccountName:  cice
This is on a Windows 2012 Server with win 7/8 clients.
The Profile appears in the folder as cice.v2 if that makes any difference.
I have also set up folder redirects so that the documents and pictures redirect to the homefolder
Profilepath you need to add on .v2 in your script. Vista/W7/W8 appends .v2 to profile path to distinct between xp and later profiles
i.e. if your profile path for each user states:
then you need to do remove-item
\\MainServer\Pro\cice.v2
Documents folder looks like a permission issue - access denied. Who are you running the script as? Does that account have permission to delete the folder?
Running the script as administrator on directly on the server.
However looking into it I cant delete the folders manually with out right clicking and taking ownership of them :(
Is there a way to code that into the script?
Sounds like the user has exclusive rights to their mydocuments.
When you set the folder redirection did you tick or untick "grant users exclsuvie rights to their mydocuments?"
http://technet.microsoft.com/en-us/library/cc782799(v=ws.10).aspx
If that box is ticked then I would expect to see what your seeing.
Powershell you can useaccesscontrol.filesecurity class to do a setowner
http://msdn.microsoft.com/en-us/library/system.security.accesscontrol.filesecurity(v=vs.110).aspx
QUick example I found on the net http://stackoverflow.com/questions/17031552/how-do-you-take-file-ownership-with-powershell (see Update and answer)
