I need to write a script to copy 5 odd files out of a list of about 80 these 5 files are spesific to the machines we produce
the reason is so that anybody can do it without requiring to know which files are required. these files need to be copied to 2 locations. i have set it up so far to save from a USB stick onto the C drive.
this is my code so far
now in order to make it easy for me to set up the range of scripts for each machine type (i.e. one script per machine) I want the machine name easily editable (I'm trying to use a variable but it don't work). I would also like to just list the file names at I which to copy at the top, so that replace test.txt with file1,file2,file3
any help would be much appreciated
'//// Vareables////
const MACHINE_TYPE = ("this is where i want machine name")
'//////// Main Routine //////
If (Ask("copy all files for MACHINE_TYPE")) Then
do_copy()
Else
Msgbox "!Aborted!"
End If
Wscript.Quit()
'///////Ask//////
Function Ask(strAction)
' This function asks the user whether to perform a specific "Action"
' and sets a return code or quits script execution depending on the
' button that the user presses. This function is called at various
' points in the script below.
Dim intButton
intButton = MsgBox(strAction, _
vbQuestion + vbYesNo, _
L_Welcome_MsgBox_Title_Text )
Ask = intButton = vbYes
End Function
'//////Copy the Files/////
Function do_copy()
Const OverwriteExisting = TRUE
Set objFSO = CreateObject("Scripting.FileSystemObject")
objFSO.CopyFile "\scripts\copy\start\test.txt" , "c:\target\1\", OverwriteExisting
objFSO.CopyFile "\scripts\copy\start\test.txt" , "c:\target\2\", OverwriteExisting
End Function
