Scripting new VHDx using PowerShell
7 Aug 2012
Scripting new VHDx using PowerShell [Resolved]
Hi All,
Got a bit of an issue when I'm trying to script the creation of a new VHDx.
If I open Powershell and send/type the following command it creates a new VHDx file;
Code:
NEW-VHD -Fixed -SizeBytes 2GB -path "E:\Virtual Machine VHDs\Test.vhdx"
However if I try passing the parameters by using the run command using this;
Code:
powershell NEW-VHD -Fixed -SizeBytes 2GB -path "E:\Virtual Machine VHDs\Test.vhdx"
I get this error;
Code:
New-VHD : A positional parameter cannot be found that accepts argument 'Machine'.
At line:1 char:1
+ NEW-VHD -Fixed -SizeBytes 2GB -path E:\Virtual Machine VHDs\Test.vhdx
    + CategoryInfo          : InvalidArgument: (:) [New-VHD], ParameterBindingException
    + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.Vhd.PowerShell.NewVhdCommand
However if I use the run command with this;
Code:
powershell New-VHD -Fixed -SizeBytes 2GB –Path E:\NewVHDFile.VHDX
it then works.
I can only assume it's something to do with spaces between my directory but I've tried playing about with quotes and no luck!
Cheers Swain90
You can call paths with spaces in, but you do have to do funky things sometimes to make it work compared to just calling a .ps1 script file.
This creates a new directory with a path in for example using single quotes:
Code:
PowerShell.exe -Command "& {New-Item -Type 'Directory' -Path 'C:\Temp\New Folder'}"
Using this from the run command has resolved the problem
Code:
powershell NEW-VHD -Fixed -SizeBytes 2GB -path 'E:\Virtual Machine VHDs\Test.vhdx'
I have no idea why M$ have swapped to using single quotes for this function !?
