Scrolled window screen capture?
18 Feb 2006
Had a quick google, but can't seem to find Apps that are highly recommended. Looking for a screen capture program that'll allow me to get the whole window, like the whole web page. Used to use one on Windows, but it's not available on the Mac. I use Skitch/Grab, but those don't do the scrolling.
Any ideas?
Ta :)
Quicktime 7 will screen capture now :)
File > New > Screen capture.
If you mean screenshot..
http://www.apple.com/pro/tips/screenshots.html said:
Hold down the Command, Shift, and 4 keys, then press the Spacebar. Instead of a cross-hair cursor, a small camera icon appears. When you move this camera icon over the element you’d like to capture, that element is highlighted. Click your mouse or trackpad, and you’ve captured a screenshot of just that element — no further cleanup required.
Good question skye, one I'd like to know the answer too.
These are all the file options I get for QT7? :confused:
