A blast from the distant past!
My father died a few weeks ago and has left me his old Epson GT-9500 scanner. As much because it was his as well as that it scans superbly, I want to continue keeping it in service.
He used it with a computer I don't have access to in which he installed a SCSI to PCIe adaptor, but I am limited to Windows 10 and 11 laptops with USB ports.
I cannot however find a simple means of converting SCSI 50 pin to USB. Is this simply because it is a non-starter or is there a straightforward way, please?
I have a parallel to USB adaptor but the scanning software products I have tried all need SCSI, so the scanner's parallel port is of no use; Device Manager confirms that neither Windows 10 nor 11 laptop detects that a powered-on and ready scanner is connected. Yes, the SCSI 'terminator' switch is set to 'on' since there are no other daisy chained SCSI devices in the circuit, and the SCSI ID is set correctly.
Thank you!
Thank you!
