AmDaMan said:LOL!!! quality replies, sorry I look at motors so much I forgot there were other forums![]()
lozza23_uk said:leave the dirt on there, adds to the sound!
got bored of rubbing the print off my cymbals, and usually crack them before they have time to get dirty now anyways.
William said:Looks like corrosion from water or your sweaty fists flailing about. Brasso should clean it if you go with the grain of the cymbal.
starscream said:I'm impressed with the number of coherent sentences in a thread full of drummers
Dave's right. You shouldn't be cracking cymbals at all if you have good technique. Unless you're using Ahead sticks, in which case you might as well be hitting them with baseball bats.lozza23_uk said:got bored of rubbing the print off my cymbals, and usually crack them before they have time to get dirty now anyways.
Dave said:Don't clean with Brasso - it removes any protective layer your cymbal has too. This leads to the same thing happening, but in a shorter space of time.
