Scuzi screws up again
Does anyone else think the headline is a bit retarded? Should "Plane lands on other on runway" not be "Plane lands on ANOTHER on runway"...
Some planes have very poor visibility out the front on approach. The aircraft I've flown are particularly good tho, especially the Grob 109.
You don't need to flare a craft like that though (flaring is angling the aircraft upwards while dropping throttle to use it as a big speed brake), you should still be able to see out front.:confused:
The picture probably doesnt tell the whole story of course, and the pilot may well have had a sick plane already, among other possibilities. Still seems weird though..
How did it stay on top of the aircraft? The Red one was said to be waiting to take off ie stationary.
Did it just stop dead when it landed on top!?
