allllec said:Infinity > Ninja? in terms of cooling.. ?
O dear the ninja is still betterJoe42 said:SPCR review comparing it to the Ninja here
Massive Attack said:O dear the ninja is still better
Is it?Massive Attack said:O dear the ninja is still better
This heatsink will beat the Ninja with a high speed fan. So those using low airflow fans should get the Ninja, and those using high airflow fans should use the Infinity.spcr said:Nevertheless, we should stress that these results apply specifically to low airflow situations that are of interest to silencers. It seems quite likely that the Infinity could reverse the standings if the two were tested with a noisy, high speed fan, as it would be helped by its larger size and the closely spaced fins around the heatpipes.
yes but who is going to buy a monster cooler just to put a loud fan on itJoe42 said:Is it? This heatsink will beat the Ninja with a high speed fan. So those using low airflow fans should get the Ninja, and those using high airflow fans should use the Infinity.
This being an overclockers forum with many users suffering the noise of fans such as the delta which moves 180cfm compared to the 40ish of the fans spcr used, i would say for the majority of people here the infinity will be better whereas for the majority of spcr readers the ninja will be better.
It all depends on the fan.
Well you wouldn't buy a tiny cooler to put a loud fan on. Anyone who wants the best performance from air with a high airflow fan will buy it.Massive Attack said:yes but who is going to buy a monster cooler just to put a loud fan on it
Joe42 said:This heatsink will beat the Ninja with a high speed fan. So those using low airflow fans should get the Ninja, and those using high airflow fans should use the Infinity.spcr said:Nevertheless, we should stress that these results apply specifically to low airflow situations that are of interest to silencers. It seems quite likely that the Infinity could reverse the standings if the two were tested with a noisy, high speed fan, as it would be helped by its larger size and the closely spaced fins around the heatpipes.
Its a scythe Ninja with double the fins. It will logically be better with higher airflow.james.miller said:They said 'quite likely', not 'will'.
