Scythe KAMA-BAY and LianLi V2000B
18 Jun 2005
Anyone have experience with the Scythe KAMA-BAY. Basically like a Coolermaster 4in3 and has a 120mm fan in the front.
Was thinking this would work well in a V2000. You could have it blowing air in towards gpu or possibly cpu area, and reverse the rear fan so it is exhausting air along with the squirrel fan.
I never understood the point of lian-li having the rear fan blowing air in anyway in the plus models. I always thought they worked best relying on negative pressure created by the rear fan sucking cold air through the case. Did they resort to changing it and adding the squirrel fan over gpu's causing so much heat buildup ?
Anyone ?
